power cms adds code " "
Thread begun 2/06/2013 4:55 am by Stuward | Last modified 2/06/2013 1:43 pm by Jason Byrnes | 5072 views | 5 replies |
Stuward
When I type new text with the powercms editor, most of the time when I check in the 'Code' view these marks are added:
Ik happens on several websites I work on. The effect on the website is that text stays in one line. Is there a solution for this?
Kind regards, Stuward.
does it insert one   between each word, or multiple?
What kind of content are you adding?
Are you copying it in from another source?
Are you using the tab key? That will usually insert 4   entities, but the standard space key should not.
Stuward
Hi Jason, her a copy of the text (code-view)
We ondersteunen je om wereldberoemd te worden bij de A-klanten die groei van jouw organisatie mogelijk maken. Het richtgetal is 15% meer omzet.
Alles in de Vliegwiel Cyclus is erop gericht om 15% meer omzet te halen.
Between each word
just text
No, typing it clean, from scratch.
No
it occurs on various browsers both on PC and MAC.
I am not able to reproduce on my end.
Stuward
Thanks Jason, solved. It occured when cutting and pasting text directly in the editor only. A work around is pasting it 'as plain text' from the editor menu.
Stuward
yes, that's why i was asking in my initial reply if you where copying and pasting from another source.
