CSS Form Builder and Data Assist
Thread begun 2/05/2013 3:12 pm by wellsjm435768 | Last modified 2/06/2013 11:14 am by Jason Byrnes | 2016 views | 3 replies |
wellsjm435768
I have created a "new from blank" custom form and would like to utilize the data assist pages feature or something like that in order to create my db tables. Is this wishful thinking or is this actually possible?
Could someone please offer advice?
The Data Assist create pages wizard wont be able to work with the form you create. If you saved the form design as a preset, you could select that preset in the Create pages wizard under the design preset section.
then on the manage pages section, you can set the element types and validation to use in the fields settings section.
wellsjm435768
Jason, when I created the form in CSS Form Builder I saved it as a preset. When I go to CSS Form Builder the preset is an option from "Choose a Form" section. However, if I go to Webassist>Database>DataAssist Pages and look under "Application Type" it is not there. Am I looking in the wrong location?
Only design presets will be available in the Data Assist wizard, not form content presets.
