Spam Email issue
Thread begun 2/05/2013 12:12 pm by Kumel | Last modified 2/27/2013 9:25 am by Jason Byrnes | 11739 views | 23 replies |
Kumel
Spam Email issue
I got a form page in my home page..
The entire works fine.. But i get lots of spams from that form in my home page.
www.webbgen.com
I keep getting fixed enteries.. with phone number as fixed and name and email randomized... & in comment box : rq jfs,odd,ugg,gfh,qls,vxu,uuf.,ugg australia,cnldq,nmbgy,,sjsjwtn.himjvdy,ugg,jmm,ubo,ces,dcf?arn,biu,ugg soldes,sth,wsk,qze,rza.
and those above words got links n urls in it..
Looks like someone is trying to hack or something..
They dont visit the website & fill but they r doing by hacking or in some other way..
Please help me out in this..
Is this problem going to be solved if disable entering URL in comment box in the form..? if yes then how do i do it...? like can i get the codes for that?
Please help me on this ASAP
do you have server validation on this form.
Make sure you are using server validation, in server validation you can specify that a filed only accept a certain data type. For example, use phone number validation for the phone number field, etc.
make sure that both the server validation and the universal email behaviors use the same trigger.
Kumel
All i have used is spry validation for email (email format)and phone number (phone no format)..
What about the comment field?
Even if i insert a spry validation field for Comment box,. how do i disable entering urls in that text field .
spry validation can be disabled by disabling java script in the browser, it should not be relied on for preventing spam.
use server validation instead.
you can use the alpha numeric validation type for the comments field to allow letters and numbers to be inserted, this will prevent URLs.
or you could use regular expression validation.
if you look at the documentation, there is an example of a URL regular expression that can be used.
Kumel
Okie.
This is the 1st time i heard about that.:)
anyways can you tell me how exactly do i do server validation?
to add server side validation go to WebAssist -> Forms -> Validation -> Server Validation.
Select the validation type, then click the lightning bolt next to server variable and select the form element to validate, then click the plus button to add it to the validation list. repeat for each element you wish to validate.
to show a validation message, type the message on your page and select it. Go to WebAssist -> Forms -> Validation -> validation Show if. select the validation that should trigger the error to show and add it to the list.
add a message for each validation you add to the server validation behavior.
on the data bridge support page, see the "Add server validation to your web forms" tutorial for details.
Kumel
In server behavior panel i cant find this -> WebAssist -> Forms -> Validation -> Server Validation.
Under WebAssist there is only file manipulation, create new email and Utilities...
Kumel
ok no probs.. i got it now.. i had uninstalled security assist so :)
Kumel
So i have added the server validation into the thank you page.. Do i need to remove the spry validation field from the form page?
does the forms action post to the thank you page?
validation is applied to the forms action page.
only if the form posts to the thank you page should the validation be applied to the thank you page.
look at the form tag and the action attribute.
you don't need to remove spry validation, just don't rely on it for preventing spam.
