Update Record JavaScript Error
Thread begun 2/05/2013 8:46 am by CUAD | Last modified 2/05/2013 12:10 pm by Jason Byrnes | 3066 views | 6 replies |
CUAD
I just updated my Data Bridge and went to create a page where I could update a record. When I click on update I get error:
While executing onLoad in WAAB_UpdateSBV3.htm,
the following JavaScript error(s) occurred:
In File "WAAB_Update_SBV3";
initializeUI is not defined
CUAD
I also deleted cache several times.
try Restarting the computer and delete the cache once more
CUAD
I removed cache and restarted the computer. It is still prompting same error on screen when I click update single log on.
What version of DW?
What is your OS?
What extensions including version numbers are installed?
can you explain what you mean by update single log on?
that does not make sense.
CUAD
Dreamweaver CS6
Windows 7
Data Bridge Version: 1.1.3
I attached the current extensions installed.
was data bridge the last extension you installed?
Data Bridge must be installed after all of the others. try uninstalling Data bridge, then delete the cache file and re install it.
