IE10 & Images/Javascript Issues
Thread begun 2/04/2013 10:55 am by fragop363190 | Last modified 4/23/2013 10:26 am by patricia.shaw258417 | 4610 views | 9 replies |
fragop363190
Hello everyone,
PowerGallery does not work at all with IE10. All the images/javascript fancy behavior is not working at all.
With firefox etc. things work fine.
Example: At the flow gallery, instead of the mirroring effect, it shows up as double products (1 up and 1 down) making everything double. On other galleries they just don't show up properly.
Please tell me that this is something that can be fixed fast as otherwise I will need to remove the gallery totally from a website and find an alternative one.
Please this is a paid solution, it should be working fine and IE10 has been launched long time ago.
patricia.shaw258417
Power Gallery not working in IE 10
Please let me know when a fix is ready so that the Power Gallery displays correctly in IE 10 without having to use compatibility mode. Our customers are unhappy that their website galleries are not displaying properly.
I am hoping you will have a fix ready soon.
I believe this is fixed by using an updated copy of the mootools files.
patricia.shaw258417
Power Gallery issue with IE 9 and IE 10
  I believe this is fixed by using an updated copy of the mootooms files.
patricia.shaw258417
Please let me know if the issue is now corrected.
Errors on trying to connect to your server.
patricia.shaw258417
Power Gallery Issue for nrileyconstruction.com
sending private message
i updated the /powergallery/js/mootools-core.js and mootools-more.js files with the versions attached to correct the problem.
patricia.shaw258417
Thank you very much!
