File Upload Field error
Thread begun 2/04/2013 1:49 am by stephen287384 | Last modified 2/05/2013 9:06 am by Jason Byrnes | 1616 views | 3 replies |
stephen287384
I am trying to add a file upload field to a form without success. I am getting the following error see attachment:
I have only 2 extensions installed, Design Extender 1.1.1 and Data Bridge 1.1.3
can you give us some steps on how you are adding the field to reproduce this error message?
at what point do you get this message?
Are you adding the file field to the form by going to Insert -> Forms -> File Filed? Do you get the error when the file field dialog box opens?
or do you get the error on adding the file upload behavior?
please give a more detailed description of your steps to produce the error.
stephen287384
The error occurs when the form is being built. I create the form: webassist>forms>build new form then create a field (type file). When the form is then created the error appears
