Dropdown menu goes behind wow slider
Thread begun 2/02/2013 6:44 pm by StephenMartin | Last modified 2/04/2013 2:28 pm by StephenMartin | 5638 views | 3 replies |
StephenMartin
I've searched the forum and see this is not an isolated case. I'm thinking it might be my z index in the menu css, but not sure, and I don't want to do anything until I find out what's going on.
Here's the site: EuroSportRebuild
Can someone help me out?
Thanks.
bill3786
I had this problem with a menu disappearing behind a div with a slimscroll feature. I solved it by adjusting the relative z index values.
Looks to be the same problem, try changing the z index for the menu to be a higher positive value than the slider.
bill3786 is spot on. edit the #navigation selector in your style sheet and add:
position: relative;
z-index: 999;
to set the menu stacking order above the slider.
StephenMartin
position: relative;
z-index: 999;
Thank you Jason and Bill. Got it!
Thanks for your time.
Stephen
