CS6 forminsert.js (error2)
Thread begun 2/02/2013 11:01 am by Nutzo247 | Last modified 7/29/2013 10:30 am by mick106153 | 4984 views | 9 replies |
Nutzo247
I want to add HTML editor to a page and I get:
The following JavaScript error(s) occurred: Unable to open script file "D:\Program Files\Adobe Dreamweaver CS6\Configuration\Object\Froms\forms\formInsert.js " (error2).
I've checked the path and the fiile is not present. I've got the super suite
-Databridge 1.1.3
-Design Extender 1.1.1
-eCart 5.0.6
Also free tools 1.0.2
Adobe have removed the object/forms folder from the creative cloud version unexpectedly.
see the following thread for details:
showpost.php?p=137836&postcount=8
and this one for a fix:
showpost.php?p=137836&postcount=9
Nutzo247
It works, But it would be helpful if webassist provided the files for the fix.
Thanks again.
jamie.ghio444407
Please help ... I have this issue but I can't find the files. The linked thread says "For everyone's help I am attaching the forms folder so you can re-install all missing files " but there isn't any attachments. Please help.
the attachment is available in this post:
showpost.php?p=137837&postcount=9
designweb
This is ridiculous, web assist should be reporting to us about these issues.
You should be making a fix, not Adobe.
I can't believe I have had to find this out this way.
I am in the middle of a project and just just seems to be one problem after another with Data Bridge.
The fix should be put in the installer
This folder was unexpectedly removed by Adobe when they released an update.
Adobe have making very large changes to functionality in DW CS6 in updates which they have not done in the past. We are planning to release an update to address this issue in the installer, in the mean time, the fix to download it manually.
mick106153
Jason
I, having had the same error, hunted down a copy of forminsert.js in DW CS4. I copied it to the location specified in the error and it worked. Should I expect something to explode any time soon?
Mick
No, nothing should blow up.
mick106153
Thank you
