client wants to be able to add pages in PCMS
Thread begun 1/31/2013 12:09 pm by wbrooks199805 | Last modified 2/01/2013 11:45 am by wbrooks199805 | 3178 views | 6 replies |
wbrooks199805
I have reviewed the video and I want to be sure this can be done by me or I can get a buy a ticket for web assist to set up.
I have attached a menu that I want to be able to add pages and then add pages under more categories. Please advise
Yes, that can be done using Power CMS Template content categories.
wbrooks199805
So I do it like the video?
Is there a simple way or thats it. (I mean its simple but time consuming)
yes, the video explains how to accomplish this.
wbrooks199805
to understand better
I purchased Design extender. Should I build the a framework theme first and then make put into PCMS? And then build out the pages? The entire website needs to be able to add pages.
Also, these posts/links in the video are not menus, they are links. Is there a way do this with menus?
you don't have to use framework builder themes, but you can if you want to.
you could create the Framework builder theme, create a page from the theme, then add the PCMS Content areas to it.
Using PCMS To control the menu items can be done but ti is a bit tricky. you would create a dynamic menu, then update the recordset used by the dynamic menu, the SQL for it would be similar to what is in the tutorial, and you would need to edit the links in the menu, similar to the links in the tutorial. If you need, we can help with setting that up in a premiere appointment.
wbrooks199805
That sounds great
I will do just that. Thanks!
