metakeyword search
Thread begun 1/31/2013 11:46 am by please_help | Last modified 2/04/2013 8:28 am by Jason Byrnes | 5948 views | 18 replies |
please_help
metakeyword search
Hello~
I'm having a problem with the search function on my ecart. When I only have one word in the metakeyword field in my database, the search works fine. If I add more terms, the search doesn't return any results.
Here's a link to my search page:
products_search.php
Currently, the only search term is 'everpure.'
Thanks in advance for your help!
can you provide some more details please on how you are setting this up and a copy of the search and results pages.
please_help
I set this up with ecart and databridge. I then uploaded the product information to the mysql database. Initially, we only added one term in the search field; our product manager is currently developing the search terms.
Here's the link to the search page:
products_search.php
Here's the link to the results page:
products_results.php?ProductMetaKeywords=everpure
If I add more terms to the ProductMetaKeywords field in the database, the search doesn't return any results. I separated the search terms in the database field with commas. Could that be the problem?
1) in the database, don't separate the key words with a comma.
2) in Data Assist search, make sure the criteria is set to use the Keyword criteria type, set the comparison to Includes. Set the Or separator use a comma followed by a space:
", " (without the quotes)
3) in the search, separate each keyword with a comma:
keyword1, keyword2...
please_help
Terrific! Thanks! I'll try that and will let you know if I have any more problems.
please_help
Hello Again~
How do I check Data Assist's search criteria? I tried going through the Data Assist Search Wizard but don't see a way to modify the criteria or comparisons.
open the results page, go to the server behaviors panel and double click the Data Assist search server behavior to edit it.
please_help
This post has been deleted.
please_help
hmmm.... now regardless of what is entered in the keyword field, all the products show as the result.
The keyword field can be empty and it still returns a result with all the products in the store.
If you type 'sediment' into the keyword field, you should only see two products.
i'll need a copy of the search and results pages.
