Nested Recordsets
Thread begun 1/31/2013 11:42 am by this_is_me | Last modified 2/01/2013 7:36 am by Jason Byrnes | 2692 views | 5 replies |
this_is_me
Nested Recordsets
I am quite impressed about this tutorial and the smooth procedure.
Just one question about the automatic creation of database tables. Is there a way where I can persuade the script to create text fields in utf-8? I find latin1_swedish *very* problematic with international characters
Use Dynamic Connections to create the Database connection, in Dynamic connections you can specify the character set for the connection to use UTF-8
this_is_me
I did this, but ...
did not prevent the fields being created in latin1_swedish_ci.
attached the part from the connection file
if the connection is set to UTF-8 the character set on the database wont mater, it will insert the data using the UTF-8 character and retrieve the data using the UTF8 character set.
if you really want the tables to be set to UTF-8, then you need to edit them after they are created.
this_is_me
Ok thanks
I got a bit confused about how often this UTF-8 needs to be set.
So, if I understand correctly, the table.textfield charset is unimportant as long as the connection is set to UTF-8, right?
It would need a lot of fiddling if each text field of each db table needs to be changed manually.
the connection character set will override the character set used by the table.
