JavaScript error(s)
Thread begun 1/31/2013 10:26 am by this_is_me | Last modified 2/01/2013 10:13 am by Jason Byrnes | 3764 views | 11 replies |
this_is_me
JavaScript error(s)
I purchased Databridge and followed the installation instructions. Before this I uninstalled each single WA extension.
Then I installed (in this order):
CSS Menu Writer (2.0.6)
eCart 5.0.6
Data Bridge 1.1.3
WebAssist Free Tools 1.0.2
on DW 5.5 (Win7 / 64)
I get the following errors (see attachements)
I was hoping if I bought the 13th update of Databridge, I could avoid those errors. Can you help please?
Go to WebAssist -> Preferences in the Memento section Set the Show in dreamweaver option to Never.
In the RSS Section, check the option to disable all RSS Feeds and Check For Updates only when Memento opens.
Then go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
this_is_me
Yep!
this resolved the problem.
Thank you - also for the quick reply
you're welcome.
this_is_me
Jason, I'm sorry, but I still get errors
Everytime I click on a task in DW, like opening the Binding panel, I get now:
"While executing findDynamicSources in WA_NotifyCO_0_Gen.htm, a Javascript error occurred."
If I click OK, the Binding panel shows up but is empty. If I switch to the Server Behaviour Tab and back to the Binding panel, it is populated as it should be.
Then I try to apply DataAssist Repeat Selection and the same message pops up again. The repeat selection window does not show any recordset although it is present at the page.
Quite frustrating, bcause it keeps repeating everytime...
I want to add that I completely de-installed Dreamweaver, any extensions, re-installed DW, installed *only*
* CSS menu writer
* eCart
* Databridge
* FreeTools
in that order
you say you installed in this order:
eCart 5.0.6
Data Bridge 1.1.3
it is better to install Data Bridge last:
eCart 5.0.6
Data Bridge 1.1.3
this_is_me
OK, I give it a try
Until now I de-activated eCart and got rid of the error messages. I'll respond as soon as I am finished de-installing / re-installing.
As always, thank you for your reply
In reality, we are moving away from the stand alone extensions.
Instead of the stand alone menu writer version, i would suggest using Design Extender, if you are interested in updating to design extender, contact our sales department, they will be able to offer you a discount based on your purchase history.
this_is_me
in a way it makes sense
but I just read recently that eCart (which seems to create the problem) will stay "standalone".
I agree that packages have advantages but it is also quite expensive, after having bought each single extension. In times where everybody creates wordpress pages which is a great tool (with a lot of free modules for many solutions) professional webdesigner live not without competition from that corner.
I re-installed in your suggested order - same problem. Must have something to do with eCart5, I guess:
yes, eCart will remain standalone, but CSS Menu writer is now incorporated into Design Extender.
if you create a new site do you have the same error?
try deleting the WA_eCart/WA_DMCFG.xml file from your site.
