Security Assist menu is missing a fly-out!
Thread begun 1/31/2013 6:56 am by mrs | Last modified 1/31/2013 9:01 am by Jason Byrnes | 1501 views | 3 replies |
mrs
I have just installed the latest version of Data Bridge, then uninstalled it along with Free Tools and Design Extender (because the data assist UI broke after installing the update), I then deleted my .dat file launched and quite DW and then deleted my .dat again just to make sure, then reinstalled the extensions I'd just removed, and the menu item WebAssist -> SecurityAssist -> Manage Site Access no longer has any content within it! See image attached.
Any thoughts on how I can work around this or get it fixed?
I've looked for secondary ways of accessing the pages access manager, but can't see anything. Is there another way in to it?
Thanks.
Mat
Did you install Data Bridge last? Data Bridge needs to be the last extension you install.
I have tested using CS6, 5.5 and 5 and the menu is there on my install of DB 1.1.3.
mrs
Initially I did install it last, then I uninstalled and reinstalled in this order
eCart
Design Extender
Data Assist
Free Tools
What order should it be?
Should I be installing by the latest released by date?
I use this order:
eCart
Free Tools
Design Extender
Data Assist
