Customising The Top Menu
Thread begun 1/30/2013 6:59 pm by peterm.bruce341471 | Last modified 1/31/2013 9:19 am by peterm.bruce341471 | 2083 views | 4 replies |
peterm.bruce341471
Jason,
In the menu of the default theme there's a small inner div with rounded corners 'ps_main' which is not as high as the wrapper. Basically I just want to have a bar menu with the whole square brick highlighted full height without corners. I've found the corners under the 'ps_main' tag in the default css but can't work out how to make the div the same height as the bar. Also I'd like to change the height of the bar but can't find this either. Can you point me in the right direction, please?
Also, is it possible to design a completely new menu if I want to?
Thanks,
Peter
use Fire Fox and the Fire Bug extension to access elements on your page an locate the CSS That controls them.
to create a completely new menu, you would need to hand code the menu.
peterm.bruce341471
Can't identify the elements
Jason,
That was the first thing I tried to do. The tab element is either class="link" or class="current link" and the bar of the nab is "ps_main" but changing "ps_main" does not seem to do anything, "current link" I think is dynamically generated and not in the style sheets, "a.link" is the only one I can find and does not offer much control.
I want to reduce the height of the bar to 30px and the a.link container. I have got rid of the round corners.
i'll need a link please
peterm.bruce341471
Found Enough
Jason,
I think I've found enough to make the changes I require. I do like the webassist software but would be good if the css for powerstore could be more coherently managed. It's pretty tricky trying to pin down different elements in different style sheets.
I'll post back if I can't make the changes.
Appreciate your help.
Pete
