Shipping rule change produce JavaScript errors
Thread begun 1/30/2013 4:25 pm by robvoigt9434728 | Last modified 2/06/2013 12:33 pm by Jason Byrnes | 3764 views | 11 replies |
robvoigt9434728
I need to remove my current shipping rule and add back in US and International shipping. I am following the Thread "Recomended Approach for Domestic vs. Internations Shipping" which appears to be how I need to set up the triggers.
However I am getting the error shown on the attached file when delete the current shipping rules and attempt to create new rules.
How can we fix this so I can create the new rules? I have not seen this type of error which references a javascript file Library:Application Support folder.
Any ideas?
I have seen that error happen if the shipping rule gets duplicated in the eCart object file.
send a copy of the eCart object file from the WA_eCart folder so i can take a look at it please.
robvoigt9434728
Thanks for taking a look.That is probably it because a while back when I set up the shipping rules something got screwed up and I had to put 4 rules at $1.50 a piece to get my $6 dollar shipping! Let me know if you have an idea to correct this. At the end of the day I want to remove these shipping four shipping rules and add US and International back in.
change line 88 - 93:
//Shipping
  $this->Shipping[] = new WA_eCart_Rule(urldecode("Shipping%20&%20Handling%20per%20item"), true, "WAEC_eCart1_ShippingHandlingperitem");
  $this->Shipping[] = new WA_eCart_Rule(urldecode("US%20Shipping"), true, "WAEC_eCart1_USShipping");
//Shipping
robvoigt9434728
When I replace lines 88 - 93 with the new code, I lose all the Order Summary fields in the cart. Is that the only fix? Or does it make more sense to re-run the checkout wizard at this point?
changing those lines in the cart should not effect the order summary in the cart display page at all.
robvoigt9434728
Jason I was able to get both a US and Intl shipping rules established using the methods you wrote in a previous thread.
Can you tell me how to set the Cart page to not show the shipping charges because we will not know the Shipping Country until after the user indicated the shipping country on the Checkout page?
ALso it appears I am getting the International shipping rate regardless if the user choose US. I have two snap shots of my shipping rules attached for your reference. Thank you for your help.
provide a link please
robvoigt9434728
www.speedjumpers.com
I'm not able to reproduce.
if I add an item to the cart, it does not show shipping.
If i select the shipping country to be US, the shipping is applied at $6.00
Modify and select another country and the shipping applied is $25.
