Why do red exclamation marks appear next to a Dynamic Plugin?
Thread begun 1/30/2013 9:23 am by danny405167 | Last modified 1/30/2013 10:48 am by Jason Byrnes | 1223 views | 1 replies |
danny405167
I have several questions regarding Framework dynamic plugins. I have a page named branchesCatalog.php which has a recordset that displays five records by default. I am using Webassist repeat table behavior to display the records horizontally. I want to use Framework to include the branches on multiple pages.
Question 1)
Is it normal for red exclamation marks to appear on the page that contains the Framework plugin?
My recordSet on the branchesCatalog.php is not depended on $_GET or $_POST to display the five records.
Question 2)
Why m'I still require to enter a trigger value?
I am sending two images
The red exclamation means that there is code on the page Dreamweaver does not recognize, if the page works fine in the browser, you can ignore the exclamation marks, if not, then you should investigate why.
As for the trigger, you are using Dynamic Plugins.
Dynamic plugins are meant to be triggered on a specific value, Session, Post or GET. If you don't need a trigger, you shouldn't be using dynamic plugins, you should be using standard plugins.
