Cant edit images
Thread begun 1/27/2013 1:31 pm by paul377172 | Last modified 1/30/2013 7:37 am by paul377172 | 1878 views | 4 replies |
paul377172
Cant edit images
Hi I'm using the older version 1 of Power Gallery but in the manage images page, its not displaying the image info or allowing me to edit or delete the images. I guess i can use dataassist to achieve this but wondered what the reason is for this.
paul377172
Thanks, that problem is fixed but its not allowing me to add or delete a gallery. I closed the original ticket so cant reply to that.
it's the same problem.
in the admin_gallery/common/galleryadd.php and gallerydelete.php pages, the code for Security assist had been changed to use a different version than the original power gallery files:
<?php require_once( "../../../webassist/security_assist/helper_php.php" ); ?>
i edited that to the original version:
<?php require_once( "../../WA_SecurityAssist/Helper_PHP.php" ); ?>
there are probably other files ion the power gallery site that this has happened to, you may want to replace the power gallery files on your site with freshly downloaded copies.
paul377172
Thanks I thought that was the problem and thought i had ammended those pages but obviously not.
