authenticate using two tables?
Thread begun 1/25/2013 9:57 am by paulshoe379536 | Last modified 1/26/2013 5:55 pm by paulshoe379536 | 2522 views | 4 replies |
paulshoe379536
Is it possible to authenticate users using two tables? I have a database with multiple groups. Each group has multiple members. I am currently authenticating users by username, password, and active status. Groups (the 2nd table) have an expiration date. I would like to also setup a rule and session value if the group date has expired.
Result desired:
If the visitor logging in can not be authenticated or the group they belong to has expired, deny access.
it will take a little finagling to do this.
on the login page, edit the security assist authenticate user behavior, on the session tab, click the plus button to store the Group ID in a session variable.
you will also need to uncheck the Go To Previous page if it exists option.
next, on the login success page, create a recordset to query the groups table and use the groupID Session to filter.
you can then save the groups expiration date to another session.
paulshoe379536
Thank you Jason,
That's what I was doing but I was also trying to avoid adding the validation code to all of the pages that a member can view.
Currently, if they bookmark a page that is not the normal start page, the authentication sends them to the log in page but after logging in they are returned to their bookmarked page. I have "gotoPreviousURL => FALSE"
Code below:
if((((isset($_POST["Login"]))?$_POST["Login"]:"") != "")){
$WA_Auth_Parameter = array(
"connection" => $cpDVD,
"database" => $database_cpDVD,
"tableName" => "members",
"columns" => explode($WA_Auth_Separator,"username".$WA_Auth_Separator."password"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["username"]))?$_POST["username"]:"") ."".$WA_Auth_Separator."".((isset($_POST["userpassword"]))?$_POST["userpassword"]:"") .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"member_id".$WA_Auth_Separator."privileges".$WA_Auth_Separator."group_id".$WA_Auth_Separator."family_id".$WA_Auth_Separator."block_access"),
"sessionNames" => explode($WA_Auth_Separator,"member_id".$WA_Auth_Separator."privileges".$WA_Auth_Separator."group_id".$WA_Auth_Separator."family_id".$WA_Auth_Separator."block_access"),
"successRedirect" => "members/members_list1.php",
"failRedirect" => "index.php?failed=true",
"gotoPreviousURL" => FALSE,
"keepQueryString" => FALSE
WA_AuthenticateUser($WA_Auth_Parameter);
Maybe try creating a view that uses a join query to join the Users and Group tables, then in the authenticate user behavior, use the view in stead of the users table, this way you will be able to access the expiration column on the sessions tab.
paulshoe379536
Thank you Jason. That was a good idea. I linked the two tables on the login page using the $_POST values from the authenticate user behavior. On post, I compared my dates and set a session value if expired.
