Credit Card Not Processing
Thread begun 1/25/2013 9:29 am by jeff382039 | Last modified 1/29/2013 9:19 am by Jason Byrnes | 4020 views | 7 replies |
jeff382039
I am signed up with Authroize.net, and have implemented a highly customized store (delivery ect ect) I have set it up and tested it with the authorize.net test credit cards - everything works fine on the authorize.net end and the store end (emails are sent, order is processed) --- however, when i use an actual credit card (several people have tried) it will not allow a transaction to go through. Why are test credit cards working but not real working credit cards working?
nycfloristonline.com/
In the Power store admin settings section, make sure that test mode is not enabled on both the Store settings tab and the gateway tab.
jeff382039
Both settings for test mode are unchecked. Is there some sort of code i can put on a certain page (let me know what page) to pull the response codes from authorize.net. I was under the impression that whenever something is declined a detailed response is returned of why the transaction failed...
Thanks.
in the power store settings, you can enable debug mode, this will show details about the failure on the failure page.
jeff382039
Error
Jason, this is the error i received... no idea what it actually is. Please Help, Client is freaking!
Thanks,
Jeff
Looks like a problem with the password and transaction key:
index?page=content&id=A852&actp=LIST
In the power store settings for authorize.net, try leaving the password field blank, or entering the transaction key for both the password and transaction key settings.
jeff382039
Yes, but the test cards from authorize.net work and go through using the trasnaction key i set up.....
in the account settings for the Authorize.net account, it may still have test mode enabled, this would cause live transactions to fail.
