search problems, again
Thread begun 1/24/2013 11:31 am by Sweens | Last modified 1/24/2013 12:38 pm by Sweens | 1536 views | 2 replies |
Sweens
Hi
I've followed the DA search wizard about 15 times - and every time it doesn't work!
I want a search based on 3 differenr fields; 1 text, 2 numeric (from menus) - however, it just returns all the results, every time
Page is attached - could you point out what needs correcting, please?
Chris
the search behavior is set to trigger on an element named "Search"
if (isset($_GET["Search"]) || isset($_GET["Search_x"])) {
but the search form does not contain an element named search, the submit button is named "WADbSearch1"
<input type="submit" name="WADbSearch1" value="Submit" /></td>
change the trigger if statement to:
if (isset($_GET["WADbSearch1"]) || isset($_GET["WADbSearch1_x"])) {
Sweens
Jason, you're a star! Thanks very much.
Cheers
Chris
