I dont receive an email from form.
Thread begun 1/24/2013 8:46 am by santosbr254895 | Last modified 1/25/2013 7:42 am by Jason Byrnes | 3981 views | 7 replies |
santosbr254895
Hi Guys,
I am trying for the first time "Create a form" in Data Bridge.
I didn't change anything from the script. I just inserted SMTP server, port, email from and email to.
I have created a confirm page, but after click at submit button, I don't receive the email and it don't go to the confirm page.
I already read a lot of posts, tried to make changing, but I didn't get any result.
Thanks in advance,
Dungol
the action of the form is set to use a session variable:
<form class="Basic_Default" id="SimpleContact_Basic_Default" name="SimpleContact_Basic_Default" method="post"  action="<?php echo(isset($_SESSION["waue_contact_1_Log"])?$_SESSION["waue_contact_1_Log"]:""); ?>">
change the form tag code to:
<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>
<form class="Basic_Default" id="SimpleContact_Basic_Default" name="SimpleContact_Basic_Default" method="post"  action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>">
santosbr254895
I have changed the code , but It didn't go to thanks page and I didn't receive an email.
i'll need a link where i can see the problem, and the most current copy of the email page.
santosbr254895
I have created a sample for testing in this address:
contact.php
What version of data bridge do you have?
the most recent version is 1.1.3, make sure this is the version you have installed.
if you have a previous version, make sure to install the newer one and use the newer one to create the contact form.
santosbr254895
I´ve installed the last version, recreated the sample form, but nothing have changed. I noticed that has a exclamation sing on "Validation Show If (contact.php) prior version" into server behavior panel.
Sample:contact.php
