Recordsets loosing filter settings
Thread begun 1/24/2013 8:35 am by john70964 | Last modified 1/24/2013 10:48 am by john70964 | 1356 views | 2 replies |
john70964
Hello
I am using CS6 and data bridge.
Quite often I find that the filter settings created in a recordset are being lost.
The code is still correct in the page.
I created a recordset outside of WA and the filter does not get lost.
I am attaching a picture of the recordset and the piece of code which I hope will explain clearly.
Many thanks
John.
Your screen shot is of an entered value parameter.
Dreamweaver wont show an entered value type filter when you re inspect the recordset.
with entered value type pferamaters like this, you should be using advanced mode to manage the recordset, not simple mode.
john70964
Thank you for that information Jason.
Most valuable
Regards
John
