Redirect on Pass or Fail not working
Thread begun 1/24/2013 6:57 am by georgina_barrett_187762 | Last modified 1/28/2013 8:48 am by Jason Byrnes | 3246 views | 5 replies |
I set up a forgotten password page using the wizard. The email gets sent ok if it matches the email in the database however it doesn't redirect to the login success page. It also doesn't redirect to the login fail page if the email doesn't match.
This is my code
@session_start();
<?php require_once('Connections/extratime.php'); ?>
<?php require_once( "webassist/security_assist/helper_php.php" ); ?>
function WA_SecurityAssist_Email_1_SendMail($WA_Auth_Parameter){
$WA_MailObject = WA_SecurityAssist_Definition("mail.extratimeonline.co.uk","26","Extra Time Online","","","");
$WA_MailObject = WA_SecurityAssist_SendMail($WA_MailObject,"","","",$WA_Auth_Parameter["toAddress"],"",$WA_Auth_Parameter["fromAddress"],$WA_Auth_Parameter["subject"],$WA_Auth_Parameter["mailBody"]);
$WA_MailObject = null;
}// WA_SecurityAssist_Email_1_SendMail
if($_SERVER["REQUEST_METHOD"] == "POST"){
//WA SecurityAssist Email object="mail"
$WA_Auth_Parameter = array(
"connection" => $extratime,
"database" => $database_extratime,
"tableName" => "customercontacts",
"filterColumn" => "Email",
"filterEncryption" => "",
"columnValue" => "".((isset($_POST["email"]))?$_POST["email"]:"") ."",
"columnType" => "text",
"usernameColumn" => "username",
"usernameEncryption" => "",
"passwordColumn" => "password",
"passwordEncryption" => "",
"selectColumns" => array("username","password","Email"),
"sessionVariables" => array(""),
"successRedirect" => "login.php",
"failRedirect" => "noemail.php",
"keepQueryString" => FALSE,
"toAddressColumn" => "Email",
"toAddressEncryption" => "",
"fromAddress" => "info@extratimeonline.co.uk",
"fromAddressDisplay" => "Extra Time Online",
"subject" => "Forgotten Password",
"mailBody" => "User name: [username]
Password: [password]",
"emailFunction" => "WA_SecurityAssist_Email_1_SendMail"
WA_Auth_ForgotPassword($WA_Auth_Parameter);
could be a php error occurring that is preventing the redirect.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
I have added that but there are no errors. This is a link to the page
http://www.extratimeonline.co.uk/new/forgotpassword.php
You can see the redirect on fail doesn't work by making up an email address.
What version of data Bridge do you have?
I think this is an issue that was fixed in version 1.1.3.
If you have a previous version installed, make sure to uninstall it from the extension manager before installing the newer one.
after installing the newer version, make sure to delete the webassist/security_assist/helper_php.php file from your site, then edit the Email password behavior and click OK to have it regenerated. make sure to upload the new webassist/security_assist/helper_php.php file to the server
Yes, that fixed it thanks.
glad to hear it is working.
