Spam Generated Emails From Form
Thread begun 1/23/2013 3:47 pm by Martin | Last modified 12/26/2014 12:24 pm by Jason Byrnes | 10576 views | 19 replies |
Martin
Greetings!
I have created quite a few sites using Form Builder when it was on it's own and now that it is in Databridge.
What is starting to happen is that quiet a few sites with forms on them are now getting successful spam submissions.
I have tried everything I can think of as to how they are able to get past the 5 digit random code and the hidden validation field. I have turned of JavaScript, but the Server Side Validation still stops me from being able to submit the same info they are.
One thing I see is that most of the phone validation is being passed with only 6 digits - usually "123456", even though I have them set to 10 digit (including area code) validation. I cannot get it to successfully submit with only the same at all. I have had some validate with a domain address in the phone field.
Any ideas on what I should do to check what might be causing this issue?
I can provide examples if you can give me an e-mail address to send them to.
Thanks!
Martin
I'll start an incident so you can provide example and i can look at the problem.
gary917
Spam Generated Emails from form
I have also started getting Spam generated emails from a form on one of my websites. My customer last week started getting an average of 20 bogus emails a day from their form. The web form was generated using CSS Form Builder with the Appointment form fields, including captcha. Can you help me out so I can get the problem fixed.
double check that the Universal Email server behavior and the Server Validation server behavior both use the same trigger.
In the page I had examined with the OP, one server behavior was using the any form pos trigger and the other was using the Submit button pressed trigger, this can allow a spammer to by pass the validation and send the email.
If they both use the same trigger, by passing the validation will also bypass the email.
bryan107833
I am using your forms on many site but have one site specifically that is getting spammed through the form a lot. Can you please look at this page and let me know if there is something that can be fixed. Thank you.
you already have captcha on this form, so that will prevent spam getting through that is submitted through automated robots.
it cant prevent spam that is from a real person filling in the form though.
in the email body, you could add code to write the IP address of the person filling in the form:
<?php echo((isset($_SERVER["REMOTE_ADDR"]))?$_SERVER["REMOTE_ADDR"]:"") ?>
then when you get spam, you can ban the users ip address:
http://supportcenter.verio.com/KB/questions.php?questionid=504
bryan107833
Sorry, there is actually 2 forms on this site and I attached the wrong page although both pages have captcha. Below is a copy of one of the spam emails and it definitely does not seem like a person is filling these in. I also attached the other php file. Thanks.
Form Submitted: 3-28-2014 | 11:09 AM PDT
Student first name: Bailey
Student last name: pRIjOJErjzg
Birth date: 10121985
Gender: Male
Admission grade: 4th grade
Admission year: 1985
Current grade: 7th grade
Current school: NGzRNyuUyV
First name: Bailey
Last name: XfoMizlZeZjrnpjly
Email: steep777@yahoo.com
Address 1: EZBaOxJfowzgCdK
Address: RrslNbkEgqDtHndeo
City: New York
State: UT
Postal Code: 3475
Phone: 69094058637
Country: USA
Hear about: VhBIYYKUrVZMwmySjDJ
Comment: Have you got any qualifications? buy hydroxyzine comparable NCPDP Reject Code, if one applies.
order furosemide Maintenance 21, 29, 40, 42, 43, 53 Relationship Code 9, 11, 15, 54
topamax online pharmacy (Provide Betty with DOB and SSN)
Hidden Field:
bayschoolappf submit: Submit
on that page, the validation code block comes after the universal email code block
UE is at lines 7 - 93
validation is at lines 94 - 125
rearrange that so that validation comes first.
david_wypasek441666
Several sites - same problem: Spam emails with and without captcha
In the same basic time frame, starting at the end of March through today (4/16/14) I have several (3-4) sites that use the UE webform, some with captcha and some without and all of them are now getting spam emails - most of them are blank.
I tried re-uploading the webforms, and I'm thinking of trying to re-upload all the Spry and other files, but seeing the validation before the UE code, I just reviewed and it's that way now.
Does the Open SSL problem Heart Bleed have anything to do with this?
Heartbleed would not have anything to do with this.
On the forms that have server validation, make sure that the Server Validation comes before the UE code block./
also make sure that they both use the same trigger.
If the UE Code block uses the button press trigger, use the same button press trigger for the validation.
Server validation will only prevent automated spam, it will not prevent a person from filling in the form with spam.
