Add to Cart Button...
Thread begun 1/22/2013 3:03 pm by daniel279790 | Last modified 1/24/2013 1:20 am by daniel279790 | 1965 views | 4 replies |
daniel279790
Hi There
I'm having trouble with my Add to Cart Button. I want it to redirect to my Cart when clicked. But instead it just reloads the same page.
Looking on these forums it looks like a common problem, but I've tried all the potential solutions - removing spaces, adding @session_commit(); to the redirect bit etc etc. But nothing seems to be working.
Any solutions would be great.
I'm using PHP Ecart 4.5.2.
The dynamanic page is...
choose.php
And I want it to redirect to...
fixmy_cart.php
Many Thanks in advanced.
i'll need a copy of your pages so i can examine the code.
daniel279790
Hi Jason
I've attached them. The page with the Add to Cart Button is customise/choose/choose.php
Many Thanks
add the following code at line 1 to turn on error reporting:
error_reporting
(E_ALL);
i bet you get the headers already sent error.
at line 89, you include the init.php file:
include($_SERVER['DOCUMENT_ROOT'].'/init.php');
in the init.php file, you have some HTML that is being generated.
this HTML is being output to the page before the doctype tag (it also includes it's own doctype tag, causing 2 doctypes, and head sections which is bad HTML format) , and also before the header function to redirect the page.
the header function will fail if there is any output on the page before it.
daniel279790
Thanks for the help Jason
I think I was being too clever for my own good with the creation of the init.php file, I'm going to go back to basics and try again, hopefully the re-diredct will work then. :)
