Image File Upload Fail
Thread begun 1/22/2013 10:37 am by gpaul | Last modified 1/22/2013 1:23 pm by Jason Byrnes | 2463 views | 4 replies |
gpaul
I am unable to successfully upload an image. I have other files and sites that have worked as expected, and I have tried duplicating, having an issue here. I have attached the helper file.
Hopefully you can point me in the right direction
Gary
This is the upload script.
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../images-memorial",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "2",
'ResizeWidth' => "300",
'ResizeHeight' => "120",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End?>
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(WA_DFP_AnyUploadSuccess()){
WA_DFP_UploadFiles("WA_UploadResult1", "memimage", "3", "[ExistingFileName]_[Increment]", "true", $WA_UploadResult1_Params);
gpaul
I should have added, I have error reporting on and I am getting this
array(1) { ["memimage"]=> array(5) { ["name"]=> string(11) "newtodd.jpg" ["type"]=> string(10) "image/jpeg" ["tmp_name"]=> string(14) "/tmp/php8WGooX" ["error"]=> int(0) ["size"]=> int(8090) } }
Notice: Undefined index: memimage in /var/www/html/gary/upload-memorial-images.php on line 29
Notice: Undefined variable: userid in /var/www/html/gary/upload-memorial-images.php on line 98
Gary
the helperphp_php.php file doesn't help much.
i need a copy of the upload-memorial-images.php file please.
gpaul
Please find attached two file. They are both copies. I am using PDO to connect.
File 1 is the first form page create-memorial-copy.php
The second is used for insert and for more file uploads.
Thank you for your help
Gary
you are binding to the image column using the post:
$memimage = $_SESSION['memimage'] = trim($_POST['memimage']);
there are 2 problems here:
1) This code comes be fore the code to upload the file.
2) You should be binding to the server file name biding in the WA Uploaded files group instead of using the post.
