dynamic form fields
Thread begun 1/22/2013 8:06 am by Sweens | Last modified 1/22/2013 9:40 am by Jason Byrnes | 2153 views | 5 replies |
Sweens
dynamic form fields
Hi
I'm trying to follow the tutorial ecart_populate_checkout_fields.pdf in order to b ind the dynamic fields to the form fields on my 'checkout' page (built using the wizards).
However, when i try to access the fields, they are 'blocked' - like when you hover over a non-editable region in a template page. I've looked at the code and it's within the 'content' area, which is definitely marked as an editable region.
I can supply the page code if required.
Chris
yes, please send a copy of the page and a screen shot showing the issue.
Sweens
Thanks Jason txt file attached.
I managed to attach the correct values once I realised that the session variable is called SecurityAssist_UserID, not UserID as in the tutorial!
However, the area is still 'locked' - I tried a screenshot, but the cursor is not shown, so it's not much use. the symbol is like a roadsign - a circle with a diagonal line top left to bottom right.
Chris
instead of changing the file to a text file, please compress the original php file into a zip archive and attach the zip file.
Sweens
zip attached.
Chris
I'm not able to reproduce.
