remove password strength requirement
Thread begun 1/22/2013 7:01 am by Sweens | Last modified 1/22/2013 8:16 am by Sweens | 3606 views | 6 replies |
Sweens
HI
I'm updating an old site and have converted the plain text password to sha(1) [though I see this is now 'crackable' and I'd like to know which is better!].
I have run the SA wizard for the register/login/forgot/userupdate pages and selected sha(1) encryption for the password field.
However, when I go to log in, it won't grant access unless the password includes at least 3 letters and 2 numbers. Given that the old password didn't have this requirement, how can I remove it from the new pages so that users can still log in (to be advbised that they should change their password)?
Many thanks
Chris
  [though I see this is now 'crackable'..].
Where do you see that? Please provide more details.
When you run the security assist wizard, on the manage pages tab, you can go to the Field settings section to set the password requirements.
To edit the requirements after the pages have already been created, select the password filed and click the blue bounding box to trigger the spry validation settings in the property inspector. Also, edit the server validations server behavior.
Sweens
Thanks Jason
Will look at the Spry.
The use of sha91) enceyption is advised against at faq.passwords.php#faq.passwords.fasthash
HTH
Cheers
Chris
Security Assist 2 / Data Bridge does support the other Crypt() and Hash() encryption types.
Sweens
These are both listed as available encryption types in Data Bridge/SA !
Yes, that is why i said Security Assist and Data Bridge do support them if you are worried about SHA1
Sweens
Apologies - misread your reply!
