news page content not displaying
Thread begun 1/22/2013 4:07 am by JamieEff | Last modified 1/23/2013 10:27 am by Jason Byrnes | 5007 views | 10 replies |
JamieEff
Hey Jason
Have created a news section using databridge
I am trying to get it to display the news item here:
news2.php
By default, when you navigate to the page it should be the most recent article.
As you can see, the news navigation is displaying fine (and when clicked should open in the same page)
Jamie
i'll need a copy of the page so i can see the code.
JamieEff
here you go Jason and thanks
also, on the same site... am using a show region for the click hereon this page councillors.php but it isnt working as click here shows regardless...
<?php if ($totalRows_Councillors > 0) { // Show if recordset not empty ?>
  <a href="mailto:<?php echo $row_Councillors['CouncillorsEmail']; ?>">click here</a>
  <?php } // Show if recordset not empty ?>
you are using the same recordset for showing the news items and for showing the links.
you need to use one recordset for showing the links.
and a second recordset for showing the news items.
in the second recordset, se it to filter the ID column on the ID URL Variable.
to show a default news item, go to advanced view for the recordset, and set the default value for the URL parameter to the ID of the news item that should be the default.
for the issue with the email link, the if statement is just checking that the recordset is not empty, since the recordset is what is used to populate the list, it is not empty (otherwise the list would be empty to, no?)
I believe you want to be checking if the email column is empty?
<?php if ($row_Councillors['CouncillorsEmail'] != "") { ?>
JamieEff
Thanks JAson
Re:
Not sure what I need to put here... and the default would be the most recent article...
Re the show if issue, the recordset is empty (there is nothing in the column in the database).
the i guess you would need a third recordset to lookup the most recent article, and use that one if there are no records in the other recordset.
those aren't the same thing. an empty column in the database does not mean that the recordset is empty.
the recordset is clearly not empty, otherwise, you would not be showing the names in the list.
JamieEff
ahhh sorry, wasnt making the distinction re the show if - have now done so! workign a dream :D
JamieEff
Hey Jason
Am struggling with the news thing still.
Have tried doing it on another site with its blog. blog.php
I have got the blog navigation working fine... and when yuou click on a certain blog title it opens the relevant article on the left hand sdie
However, I cannot figure out how to get it so that when you click on the main 'blog' link in the top navigation the most recent article is displayed with the navigation down the right and then any subsequent blog navigation selections opens in the same page....
Many thanks in advance
Jamie
if you order the recordset by the ID column in ascending order, the most recent blog will be the first record in the recordset.
JamieEff
I just cant get it to work.. have tried playing around with a variety of different orders. At the moment I have it set upa attached images) of both recordsets and the table itself
Basically as its set up at the moment the most recent article is visible in the left hand column, but none of the links work to navigate the other blog titles....
