Results Delete Button
Thread begun 1/21/2013 7:18 am by john70964 | Last modified 1/22/2013 1:20 pm by Jason Byrnes | 3956 views | 3 replies |
john70964
I created a Dataassist Results and update page.
The Results Page contains an edit and a delete button.
The edit page button did not work first off and was opening the wrong page.
I corrected that.
However the delete button link is not working
Code is
<input type="button" class="formButton ResultsPageButton unstyled DeleteButton" value="" onclick="document.getElementById('WADADeleteRecordID').value=<?php echo($row_WADAboatsq['RecNo']); ?>;document.getElementById('deleteBox').style.display = 'block';document.getElementById('deleteMessage').style.display = 'table';" /> Line 386
I am attaching the file in a zipped format, perhaps you can see the problem.
When creating pages I cannot see a delete page.
Please see attached picture
How is this carried out please?
Many thanks
john
john70964
Thanks Jason
I am managing to get the update and delete buttons working OK now.
I wonder if it had something to do with the field name "Class" I mentioned previously.
Having changed that field name the wizards seem to work better.
Class is probably a reserved word by javascript.
PatriceWebAssist
What was the solution to this? One of my sets is doing this also. The delete button shows up, it just doesn't have any action when pressed.
<input type="button" class="formButton ResultsPageButton coolsmallerfont DeleteButton" value="" onclick="document.getElementById('WADADeleteRecordID').value=<?php echo($row_WADAtestimonials2013['testimonials_ID']); ?>;document.getElementById('deleteBox').style.display = 'block';document.getElementById('deleteMessage').style.display = 'table';" />
Other sets in same admin are ok. I've redone this set 3 times.
send a copy of your page please.
PatriceWebAssist
Thanks... attached
I dont see any obvious issues in the code.
PatriceWebAssist
Thanks for finding it, Jason. Posting solution here in case someone (including me!) needs to review.
"In the results page css, i edited the position attribute for the .black_overlay and .messageContainer classes to fixed to correct the problem."
