Can't use any of the "add" features
Thread begun 8/10/2009 1:17 pm by shaun313087 | Last modified 8/11/2009 10:11 am by Eric Mittman | 2695 views | 1 replies |
shaun313087
I'm using the latest version of Surveyor on DW CS4 on a Mac. I'm trying to use several of the built in features such as adding a column break or adding a new item but nothing happens. In fact, none of the "add" features do anything for me.
In the HTML site map interface are you able to see the items in the add option? Are you able to click on any of these or does it not allow you to?
When you are using the interface are you using only the mouse to navigate and make selections? If not please give this a try, I know that sometimes the interfaces can act strangely if you use the keyboard at all including the enter key.
Are you able to make other changes to the xml site map, like adding in a new item in that map?
