Create Email Message
Thread begun 1/20/2013 9:42 am by Andrew Dodd - ADDIGITAL | Last modified 1/20/2013 11:48 am by Andrew Dodd - ADDIGITAL | 1234 views | 1 replies |
I've created a page with a form on it, but when using the Create Email Message behaviour, the for or its values aren't selectable - all I can select are Server Variables - have upgraded to the latest version, deleted the cache file etc..
Interestingly, I have to name the form fields longhand (source code view) as the properties palette doesn't seem to do the job - I type the name in (for example frm_contact_name) and it disappears, but is there in code view.
Are the two connected? Page can be seen at contact.php
See attached screenshots!
DW Version is 12.1 Build 5966, OS X 10.8.2
TIA
Andrew
Problem solved - was DW having a hissy fit!
