Site Import 3.0.2 not working
Thread begun 8/10/2009 1:12 pm by latellogroup375248 | Last modified 8/17/2009 10:04 am by Jimmy Wu | 5177 views | 8 replies |
latellogroup375248
I have recently updated to SiteImport 3.0.2 and I cannot get it to work at all now. I keep getting the following error.
"While executing onLoad in WA-IMportsite.htm, the following JavaScript error (s) occurred:
Infile "WA_ImportSite":
init is not defined.
Can you please help me with this?
Thanks in advance
Jimmy Wu
Try deleting your win/mac filecach. Here's a thread that takes you through how to do this if you don't know how:
showthread.php?t=1589
latellogroup375248
Tried this. did not work
Originally Said By: Jimmy Wu
I tried this but it did not work. I uninstalled 3.0.2 and reinstalled 3.0.1. I am using Win XP with CS4. Any further suggestions would be nice but I guess I will wait till next update and try that one.
Jimmy Wu
Which other extensions do you have installed currently?
latellogroup375248
I pretty much have everything installed that came with supersuite and I also have some php extensions from adobe. They allow me to code numbers dates and stuff like that the same way as in cold fusion.
Jimmy Wu
When you upgraded, did you remove the previous version first or did you install over it? When installing extension updates, its always a good idea to uninstall the previous version before installing the update.
latellogroup375248
I did not realize this and did not do that. I will uninstall the old and install the latest and see if that works. Will Let you know.
latellogroup375248
It's Working!!!
Great job! It appears to be working now. Will let you know if anything else changes. It did not want to work until I deleted the Wincache file in the configuration first. FYI. It kept saying there was an error and dreamweaver needed to close until I deleted that file.
Jimmy Wu
Good to hear. If you have any additional issues, feel free to create a new thread or ask here if its related.
