Add to Cart Button causes error
Thread begun 1/18/2013 7:23 am by sjones435326 | Last modified 1/18/2013 9:36 am by sjones435326 | 1409 views | 2 replies |
sjones435326
Hello, I have went through the instructions several times. When I add the Dynamic "Add to Cart" button, and upload all of the files. I then get an Error - "HTTP Error 500 (Internal Server Error):" - after several attempts I have verified that if I comment out the code that is generated at
Line #8 <?php $Subscription->GetContent();?>
Then the page will show up.
I will attach the file.
Any idea of how I can fix this?
Thank You!
You have named both the cart object and the Connection "Subscription". This is causing the error.
you must use unique names when creating application objects like the Connection and eCart objects, they cannot use the same name.
sjones435326
Thank you Jason! I will eventually learn.
