USPS Shipping Amount Incorrect
Thread begun 1/17/2013 2:14 pm by michael378527 | Last modified 1/21/2013 10:14 am by Jason Byrnes | 4136 views | 8 replies |
michael378527
The shipping is calculated correctly for a quantity of 1 but for all other quantities the shipping amount is not even close. I have the weight stored in oz's in the database. How can I see what is being sent to USPS and what is being received back. USPS is not able to help without this information.
Except for this all features of the cart have been tested and are working. I have a few things I will need to submit a consultation ticket for which I will do once I have the shipping working.
Thanks,
Michael
I added the following to the confirm.php
<pre>
<?php var_dump($_SESSION);
</pre>
and it shows that the quote from USPS is in fact correct as $4.57. The amount shown on confirm.php is $15.21 which includes the $1.50 per order charge. That means that the calculation done in ecart5.06 is not correct. Below is the dump information:
array(40) {
["HBShopping_Items"]=>
string(217) "1|WAECART|The Co-Creators Handbook|WAECART|The Co-Creators
Handbook|WAECART|handbookthumb.jpg|WAECART|29|WAECART|3|WAECART|22|WAECART|5|WAECART|19|WAECA
RT|3|WAECART|87|WAECART|66|WAECART|3 The Co-Creators Handbook (1)"
["WAEC_ContinueRedirect"]=>
string(36) "/shop/productdetails.php?ProductID=1"
<sensitive info removed>
["HBShopping_USPS_Success"]=>
bool(true)
["HBShopping_USPS_SuccessInt"]=>
bool(false)
["HBShopping_USPS_ResponseCode"]=>
int(1)
["HBShopping_USPS_Quote"]=>
float(13.71)
["HBShopping_USPS_QuoteInt"]=>
int(0)
["HBShopping_USPS_ErrorCode"]=>
int(0)
["HBShopping_USPS_ErrorDescription"]=>
string(0) ""
["HBShopping_USPS_FullRequest"]=>
string(291) "API=RateV4&XML=<RateV4Request USERID=""><Package
ID="1"><Service>MEDIA</Service><ZipOrigination>87715</ZipOrigination><ZipDestination>43358</Z
ipDestination><Pounds>5</Pounds><Ounces>7</Ounces><Container/><Size>REGULAR</Size><Machinable
>True</Machinable></Package></RateV4Request>"
["HBShopping_USPS_FullResponse"]=>
string(398) "<?xml version="1.0"?>
<RateV4Response><Package
ID="1"><ZipOrigination>87715</ZipOrigination><ZipDestination>43358</ZipDestination><Pounds>5<
/Pounds><Ounces>7</Ounces><Container>VARIABLE</Container><Size>REGULAR</Size><Zone>6</Zone><P
ostage CLASSID="6"><MailService>Media
Mail&amp;lt;sup&amp;gt;&amp;amp;reg;&amp;lt;/sup&amp;gt;</MailService><Rate>4.57</Rate></Post
age></Package></RateV4Response>
["HBShopping_USPS_FullRequestInt"]=>
bool(false)
["HBShopping_USPS_FullResponseInt"]=>
string(0) ""
the information sent to USPS is stored in the full request:
the full response is returned in the Full Response variable:
the quote is returned in the HBShopping_USPS_Quote variable:
float(13.71)
it looks to me like you have the sipping set to One Package for each item ordered, from the cart info, it looks like you have 3 for the quantity of the The Co-Creators Handbook:
4.57 X 3 = 13.71
which is the value stored in the quote.
13.71 + 150 = 15.21
Perhaps you want to ship all items in the same package?
michael378527
Checked the USPS Server Behavior
Jason,
I just went back into dreamweaver and checked the USPS shipping behavior. I had set the shipping to ship all items in one package and in step 5 of 5 the check box for Packaging is set to one package for the entire order. So there is something not working in the way that wizard stored the response. Is there a value somewhere I can change to make it work?
Michael
michael378527
Any other way to make it work?
Jason,
Thank you.
Is there a value I can change to make this work. I want to be able to put the cart in production as soon as possible.
Michael
michael378527
Jason,
Thank you.
Michael
I need to take a closer look at things.
that is why i started the incident.
If there where a simple answer, i would have already given it, but I cant tell what is wrong with only the info given here.
Jared Lui
Same issue here. Please post outcome of ticket.
Jason,
I have the same issue whereas I have all small items shipping in one box.
If I choose:
1 item A that is 0.5 oz it quotes $1.95 (the minimum quote)
If I chose:
3 item A's which is 1.5 oz it quotes $5.85 (not correct)
If I chose :
1 item A 0.5 oz
1 item B 0.5 oz
1 item C 0.5 oz
for a total of 1.5 oz it quotes $1.95 (which is correct)
i'll need to take a closer look at your site:
