Substitute for Mailto: function?
Thread begun 1/17/2013 1:09 pm by chuck429411 | Last modified 2/01/2013 8:16 am by Jason Byrnes | 8166 views | 15 replies |
chuck429411
Can I use Universal Email to make a mailto function? I am finding out that this functionality is outdated and does not work in all browsers. If the user does not have an email client set up, it will not work either. Below is the link to the page that I need to fix. I would rather not have to redesign a whole page and create forms if I don't have to. Can you tell me what the easiest way of doing this is?
contact.php
You could use universal Email to create a contact form, and have the information from the contact form sent to your email address.
chuck429411
Tips to Get Started?
Does Universal Email make the form for me or do I make one first? Does it get inserted into a div? I have used Universal Email before, but it was used for sending receipts to the customer. I just need to have a simple form with name, email, phone, comments and submit button. Your tutorials need to be updated. I have gone through all of your tutorials and documentation and still have a blank page.
you need to create the form on your page first, then apply universal email.
chuck429411
No mail
Do I need to know the SMTP server info, port number? I didn't need it last time. What about the email object? I created the form and put the bindings where they needed to go. No mail being sent though.
I am previewing in the browser from Dreamweaver and it will not send the email. Unfortunately, I can't put this page live until I get it working properly. The form with Universal Email applied to it is on a duplicate page which is not included on my site. I have attached the code if that helps. Thanks for your help, by the way.
you wont be able to test the email from your local system, the page needs to e uploaded to the remote server inn order to test the email.
chuck429411
Link to the contact page.
OK, here is the live link to the form with Universal Email. Hopefully this helps...
contact.php
who is your host?
what dod you enter for the from address?
What did you enter for the to address?
What did you enter for the SMTP Server and Port?
add the following code just before the </body> tag:
<?php var_dump($_SESSION); ?>
it will write information about sending the email to the page, including whether it was passed to the SMTP server.
chuck429411
My host is GoDaddy. I clicked the lightning bolt and bound name to the name field. The "to" address is excontact@rascp.com. I left the smtp and port blank, because that is what I did when I used Universal Email to get Ecart to send receipts.
Also, I got it to send email to my address as a test and my Outlook inbox flagged the message as spam and wouldn't let me read it. I can't get UE to send properly to excontact@rascp.com however.
You don't answer what you used for the From Address?
With Go Daddy, you must a valid email address for your domain as the from address.
you say that the email is being sent to one address, but it is being trapped in a spam folder, that may be caused by the subject line you use, or by the from address or a number of other factors.
for example, if the from address and the to address are the same, the server will treat that as spam and refuse to relay the email message.
if the email is being sent to one address and not others, that is a configuration on the SMTP server that is preventing the server from relaying to that email address.
Universal Email compiles the message, then passes it to the SMTP Server.
the SMTP Server then relays the email to the recipient. if it is relaying for some, then the SMTP Server configuration is causing it to deny the others. you would need to look at the SMTP server error logs to determine why.
