DFP and Data Assist
Thread begun 8/10/2009 12:19 pm by Steve | Last modified 8/12/2009 1:23 pm by Ray Borduin | 5587 views | 9 replies |
Steve
DFP and Data Assist
Hello,
Was working on another site to migrate from Adobe Developer Toolkit but find that an UPDATE page using the latest versions of DFP and Data Assist seem to lack the conditional means to NOT replace the file field values if no change is made to that field.
Is this something that will be improved soon? Seems a waste to have to create another page just to do an image upload if necessary because if the file field is not used it erases the current value by uploading null values.
In the meantime is there some work around???
What seems to be needed is that IF the file field has a value it should INSERT but if not changed/used that field should be excluded from the UPDATE process.
You should be able to set the default value of the upload to the current value of the field in the updated recordset. This is the value that is used if no file is included, so it should maintain the current value when set to that value.
Steve
Ray, do you have an example? I've not seen a file field have a value element so not sure if we can just add one...
For example:
<input type="file" name="image" id="image">
Are you suggesting some means to pre-populate this with the current saved value, then only of a new file is selected it replaces this same content... ?
Edit the server behavior associated with the upload. There will be a default file field that you can use and refer to the recordset directly.
Steve
Ray,
It did not work....
The recordset and value are present but in the UPDATE it failed to insert the default value as expected.
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
    'UploadFolder' => "../InvtryImages/",
    'FileName' => "[FileName]",
    'DefaultFileName' => $row_rstblinventory['InvImage'],
    'ResizeType' => "2",
    'ResizeWidth' => "650",
    'ResizeHeight' => "120",
    'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
As a test to make sure there was nothing wrong with the basic INSERT routine, I tested and confirmed that when a selection is made, it uploads and updates the DB properly.
Steve
Further tests also failed:
test 2: define default var outside the upload function:
$default_file = $row_rstblinventory['InvImage'];
    'DefaultFileName' => "[default_file]",
test 3 : test simple test string
    'DefaultFileName' => "test",
Both these failed so I have to wonder if the DefaultFileName parameter needs some further review in how it is executed in the HelperPHP.php file?
Reference:
PHP Version 5.2.9-2
MySQL 5.1.30
These two are not correct. You were on the right track in the first one.
What version of DFP do you have installed.... this setting appears to be correct:
now, it is possible that the recordset is not on the correct row once the page submits to itself. That is probably why the tutorial has you add it to a hidden form element and refer to the hidden form element in the code.
That may be the solution... is the url paramater maintained through the submit so that the update recordset would be properly filtered?
Steve
DFP 2.0.1
DA 2.0.5
The example where I defined the var just prior to the behavior should work the same as a hidden field or better since the hidden field would be latter in the document and the recordset constructs prior to the behavior.
I tried the hidden field and that also failed. Where is this tutorial you are speaking of?
That is the latest version of DataAssist. I'll create a support incident for you so that an engineer can work with you and your files directly to determine the cause and solution.
I can't spot the problem without debugging since your earlier example seems correct.
