Update before the HTML Tag?
Thread begun 1/16/2013 11:18 pm by Cologne | Last modified 1/21/2013 9:53 am by Jason Byrnes | 2224 views | 3 replies |
Cologne
I wonder if the template will update every child pages when I insert PHP code before the HTML tag.
This is not working with normal templates. Does this work with dynamic templates using framework builder?
Cheers,
Denis
No, with Dreamweaver templates, you have 2 options:
1) Use php code before the doctype on the pages created from the template
2) Control all php code before the doctype from the Template
you must choose 1 option, you cannot do both.
Using Framework builder Themes,, you can get around this limitation.
Cologne
Hey Jason,
thanks, that works, but I can't see my design :-( Only the "TemplateBeginEditable" areas are shown.
What am I doing wrong?
Cheers,
Denis
Yes, pages based on the theme will only display the content.
themes will separate the content from the design.
