Missing "/" and error: "" could not be created
Thread begun 1/16/2013 1:07 pm by randyrie405335 | Last modified 1/28/2013 9:50 am by Jason Byrnes | 2220 views | 7 replies |
randyrie405335
WebAssist DataBridge110 on iMAC running OSX 10.8.2
I've created a download subdirectory but the URL is missing a "/" between the top level directory and the subdirectory. This was an OLD problem with your CKEditor extension that I was told was fixed in DataBridge. So how do I fix this?
I am also getting this error: "Error: "" could not be created" when I try to open the File Manager. How do I fix this?
the currant data Bridge version is 1.1.2, make sure you are using the most recent version.
uninstall the previous version from the extension manager, then install the new one.
you will need to recreate the file manager after installing the newer version.
randyrie405335
1.1.2 Crashes Dreamweaver CS6
I uninstalled DataBridge 110 and installed 112 but Dreamweaver now consistently crashes as soon as I try to do anything with the HTMLEditor. Tried repeating this uninstall/install cycle three times with similar crash results. I'm attaching the DW crash report.
HELP!!??
Delete the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
randyrie405335
DataBridge 112 Crashes DW CS6
Deleted the .dat file and got to the OK button after re-inserting and re-configuring the page with HTMLEditor ... but Dreamweaver crashed again! (I am blocked from uploading a new crash report).
Also... WHERE ARE THE SKINS in 112? This option is nowhere to be found and is the SOLE reason I purchased your Editor over other brands. Please don't tell me this feature was removed with this update!!
I uninstalled 112 and went back to 110 for my sanity but now see ONLY the DEFAULT skin is available in the dropdown... the V2 and Office skins are missing. What's happened? I need the Offfice skin for three of my clients.
randyrie405335
Any updates on this issue?
I created a support ticket for this and requested contact details.
you have not updated the support ticket. Please log into your support history and update the incident with the requested information so we can look into the problem with you.
