Problem with installation
Thread begun 1/16/2013 11:39 am by TVindett | Last modified 1/16/2013 1:34 pm by TVindett | 3745 views | 6 replies |
TVindett
This is new problem for me.
Got everything set up server & database wise.
Go to insert my first bit of of CMS content. It lets me, but doesn't copy up any of the Power CMS files to the testing or remote server. So when I view the page (I'm redacting the parts that show the address) I get the following error:
Warning: require_once(WA_CMS/WA_CMS.php) [function.require-once]: failed to open stream: No such file or directory in **REDACTED** on line 2
Fatal error: require_once() [function.require]: Failed opening required 'WA_CMS/WA_CMS.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in **REDACTED** on line 2
Now its been about a year, since I created a CMS site, and maybe I'm forgetting if there's step before adding content like a packet of files or something I'm supposed to have on my local folder or something.
you will need to upload the CMS Files to the server. Should be able to just synch your site and have the needed files uploaded.
TVindett
There are no CMS files on my local drive. I guess that's part of my question, do I need to copy files from somewhere to my local site first, so they then get uploaded when i sync up to the testing server?
Because I'm already synched up.
adding a CMS Content area using DW should add the cms files to your site.
TVindett
Then it didn't. What do i do?
the cms files are located in the users configuration folder.
to locate the configuration folder, see the common installation issues pdf:
common_installation_issues.php
in the configuration folder go to shared/WebAssist/PowerCMS/CMS.
copy the files in the CMS folder to your site to install power CMS.
TVindett
Thank you very much, that did it!
