pass for ellements to other pages using sessions
Thread begun 1/16/2013 10:36 am by randyw2394710 | Last modified 1/16/2013 1:13 pm by Jason Byrnes | 2853 views | 7 replies |
randyw2394710
i created a sesion on gallery_pages.php where the form is
if(isset($_POST["add-gallery-yes"])) {
$_SESSION["gallery_name"] = "".((isset($_POST["galleryname"]))?$_POST["galleryname"]:"") ."";
then i binded the form element
<input name="galleryname" type="text" class="validate['required']" id="galleryname" value="<?php echo $_SESSION['gallery_name']; ?>" />
on this page i want the session name to appear
choose_gallery.php
<div id="error">error that gallery <?php echo $_SESSION['gallery_name']; ?>allready exists</div>
or
<div id="success">success <?php echo $_SESSION['gallery_name']; ?> has been created</div>
i have this at the top of choose_gallery.php
if (!isset($_SESSION)) {
session_start();
then to clear sesion i want to use the add_gallery button
when i try to apply this i get this error
while executing onload in wact_clearsesion.html, the following javascripts error occurred
in file wact_clearSession initializedui is not defined
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
randyw2394710
am i going this procecss correctly
yes, saving the form element to a session is the correct way to get it to another page.
randyw2394710
i can not find the WinFileCache.dat in configuration
make sure you are looking in the users directory
if you continue to have a problem, send a screen shot showing the extensions that are installed including version numbers.
randyw2394710
now i get this
attached screens
the extension manager screen shot is not readable.
