Database not being created
Thread begun 1/16/2013 9:13 am by Sally | Last modified 1/16/2013 12:05 pm by Jason Byrnes | 2162 views | 3 replies |
Sally
I'm running the DA Create Pages wizard, using the CMS template. I've told it to create the cms table for me and I can test my SQL connection in DW without problems.
The wizard runs with no errors and creates all the pages, but the cms table is not created in the database.
I've run through this a couple of times, but can't seem to figure out the problem. The only table in the database is the one I created using phpMyAdmin. Any help would be appreciated.
Thank you.
Not sure why the database table is not being created, probably an issue with the site definition settings for the testing server. Perhaps the URL Prefix and the HOST Directory arent pointing to the same place.
here is the SQL for creating the CMS table though:
[copde]CREATE TABLE `cms` (
`CMSID` int(11) NOT NULL AUTO_INCREMENT,
`CMSTitle` mediumtext NOT NULL,
`CMSContent` longtext NOT NULL,
PRIMARY KEY (`CMSID`)
) ENGINE=InnoDB DEFAULT CHARSET=latin1[/code[
you can access the database suing PHPMyAdmin or another GUI tool to execute the SQL and create the table.
Sally
Thanks for the tip. The problem seemed to be that my testing server is a subdir in my site and since we've not gone live I had both my remote and testing server pointing there so I didn't accidentally post files to the wrong directory. I'm not sure that's the best way to keep from making a dumb mistake, but it's what I was doing. Anyways, when I changed it so both pointed to the main directory, it created the database table. I hope I can change it back to the testing subdir until we go live without problems.
Thanks, Jason.
ps - for your signature, I think you mean 'were' not 'where'
should be fine to have the settings point to the subdirectory, as long as the URL Prefix and Host directory settings are both pointing to the same subdirectory.
