Activity code issues
Thread begun 1/15/2013 12:42 pm by Patrice | Last modified 3/24/2014 11:12 am by tone397472 | 7429 views | 11 replies |
PatriceWebAssist
I am struggling with facebook activity feed issues. I want to use it on a responsive design but even on non responsive layout, it floats above all other divs.
Activity box isn't being contained in a side bar div... Doing some testing now...
facebook.php
2013inside.php (pull narrow to see float issue)
Any ideas?
the facebook activity feed does not use a fluid layout. it uses a set width, if the responsive layout container does not have enough space for the facebook activity feed, it will move around. to combat this, you could use overflow: hidden on the container that the activity feed is in.
or you could over ride the facebook css to make it flud:
is-it-possible-to-set-a-fluid-width-for-facebooks-social-plugins
PatriceWebAssist
and is that why is floats above other divs?
2013inside.php
pull that narrow and see what it does...
yes it is.
PatriceWebAssist
thanks Jason
Miguel
The post is old but i have been working for some time now on responsive layouts, so ill add here the solution came with for other users
add to the styles
.fb-comments{width: 100% !important;}
.fb-comments iframe[style]{width: 100% !important;}
.fb-comments span{width: 100% !important;}
.fb-comments iframe span[style]{width: 100% !important;}
.wasocial_facebook_comments .fb_iframe_widget {width: 100% !important;}
.wasocial_facebook_comments .fb_iframe_widget span[style] {width: 100% !important;}
.wasocial_facebook_comments .fb_iframe_widget iframe[style] {width: 100% !important;}
and the facebook comment box will now turn to responsive layouts, now for the facebook feed use the same code but change each of the
with
  .wasocial_facebook_activity_feed
PatriceWebAssist
thanks Sades
tone397472
Social media Toolkit
Hi Jason,
Can you please provide me with the correct code or what ever solution to get the social media tool kit plugins responsive!?
All solutions on this forum or Stackoverflow etc. don't work!
Thanks! David
social media toolkit does not support responsive designs.
tone397472
Thanks! Jason,
Including the one in Design Extender?
