eCart Help
Thread begun 8/10/2009 10:31 am by carlos311519 | Last modified 8/10/2009 2:42 pm by Jason Byrnes | 1981 views | 1 replies |
carlos311519
eCart Help
I need help with setting up additional session variables to be transfered over to order page... I want the user to be able to select options for his order (size, cut and instructions) and have it posted in the cart as well as on the order form and such... Please help me..
Carlos Lopez
Web Designer Noob
440.396.7474
clopez@learromec.com
Website in question is www.chiathereaper.com
In the eCart object, create new columns for Size and color and any other options a product may have make sure to set the Unique attribute for these option columns.
Then in the Add to cart button wizard, select each new option column and set them to be updateable from a select list and click OK. This will add a select list to the page, in the property inspector you can populate the list with the appropriate values.
When you create the cart display, on the second page of the Display manager, you should select these option columns to display them in the cart.
