SecurityAssist Form Validation
Thread begun 1/14/2013 6:22 am by davegw | Last modified 1/15/2013 12:11 pm by Jason Byrnes | 3295 views | 7 replies |
davegw
Not sure if you are aware of this:
When one creates SecurityAssist pages from the wizard, the Form validations & Field settings dialog is not assigning the correct validation setting for UserEmail & UserFirstName. They have been swapped around:
UserEmail has no validation, but Unique box is checked
UserFirstName validation: required with type: emailaddress ; min chars 6 ; max chars 500
Cheers
Dave
make sure that you are using Data Bridge 1.1.2, if you have a previous version installed, make sure to uninstall it from the extension manager before installing the newer version
davegw
Hi Jason - definitely using Data Bridge v1.1.2 after uninstalling previous version last week.
Exact same problem on my other machine.
Have you tried it out?
Yes, i have tried it out and cannot reproduce the problem. in the pages that are being created i can see the correct validation settings being applied.
can you provide more details on the settings that you are using please, and a copy of the pages.
davegw
I've attached an image containing 3 screenshots:
1. Database & design settings
2. Field & validation settings with UserEmail selected
3. Field & validation settings with UserFirstName selected
If I choose the correct settings for UserFirstName, move onto another field, then back again to select the UserFirstName field, it reverts back to the incorrect 'email address' validation settings.
I've tried on 2 different computers with different site definitions, same problem.
so it s a problem that you see in the interface? not in the code that is generated? I thought you where referring to the generated code?
davegw
Jason - it's a problem with the wizard interface AND the client & server validation code that is generated.
If the Form Validation & Field Settings dialog is NOT accessed, then the code generated is correct.
As soon as one accesses this dialog, UserEmail form field loses the 'email address' validation in the Spry & the WA SVs.
Here are the relevant code snippets generated without accessing the Form Validation & Field Settings dialog:
$WAFV_Errors .= WAValidateEM((isset($_POST["Registration_group_Email"])?$_POST["Registration_group_Email"]:"") . "",true,1); $WAFV_Errors .= WAValidateUnique(("connTesting"),$connTesting,$database_connTesting,"users","UserID","none,none,NULL","".((isset($_SESSION["SecurityAssist_UserID"]))?$_SESSION["SecurityAssist_UserID"]:"0") ."","UserEmail","',none,''","".((isset($_POST["Registration_group_Email"]))?$_POST["Registration_group_Email"]:"") ."",true,2);
Then the Spry script:
var Registration_group_Email_Spry = new Spry.Widget.ValidationTextField("Registration_group_Email_Spry", "email", { minChars:6, maxChars:500 , validateOn:["blur"]});
var Registration_group_Password_Spry = new Spry.Widget.ValidationPassword("Registration_group_Password_Spry", { minAlphaChars:3, maxAlphaChars:500, minNumbers:2, maxNumbers:500, minSpecialChars:0, maxSpecialChars:0, minChars:6, maxChars:500, isRequired:true , validateOn:["blur"]});
var Registration_group_Confirm_Spry = new Spry.Widget.ValidationConfirm("Registration_group_Confirm_Spry", "Registration_group_Password",{validateOn:["blur"]});
var Registration_group_First_Name_Spry = new Spry.Widget.ValidationTextField("Registration_group_First_Name_Spry", "none", { minChars:1, maxChars:50, isRequired:true , validateOn:["blur"]});
var Registration_group_Last_Name_Spry = new Spry.Widget.ValidationTextField("Registration_group_Last_Name_Spry", "none", { minChars:1, maxChars:50, isRequired:true , validateOn:["blur"]});
Here is the incorrect code after the Form Validation & Field Settings dialog has been accessed:
$WAFV_Errors .= WAValidateRQ((isset($_POST["Registration_group_Email"])?$_POST["Registration_group_Email"]:"") . "",true,1); $WAFV_Errors .= WAValidateUnique(("connTesting"),$connTesting,$database_connTesting,"users","UserID","none,none,NULL","".((isset($_SESSION["SecurityAssist_UserID"]))?$_SESSION["SecurityAssist_UserID"]:"0") ."","UserEmail","',none,''","".((isset($_POST["Registration_group_Email"]))?$_POST["Registration_group_Email"]:"") ."",true,2);
then the Spry:
var Registration_group_Email_Spry = new Spry.Widget.ValidationTextField("Registration_group_Email_Spry", "none",{validateOn:["blur"]});
var Registration_group_Password_Spry = new Spry.Widget.ValidationPassword("Registration_group_Password_Spry", { minChars:6, maxChars:500, isRequired:true , validateOn:["blur"]});
var Registration_group_First_Name_Spry = new Spry.Widget.ValidationTextField("Registration_group_First_Name_Spry", "none", { minChars:6, maxChars:500, isRequired:true , validateOn:["blur"]});
theres the key that was missing. I had not been making any validation changes in my tests. I wasn't aware making changes was necessary to reproduce the problem. I will log this in our bug base to have the problem corrected.
