Results page show image, "print" searched term
Thread begun 1/10/2013 12:15 pm by jo271221 | Last modified 2/12/2013 10:26 am by Jason Byrnes | 4905 views | 9 replies |
jo271221
I want to print the year searched for on the page - directory-and-posts-horse-ads.php?id=6246&horse_year_foaled=2010&Search=Search
This should say 2 of 2 2010 Horses For Sale
I want to display the image from the post table on this page On the test copy ads_horses_results.php
I copied the recordset from the post page but then realized I have no idea why the join statement on this page does not allow me to bind to any or all fields in the post table without adding another recordset and have no idea the correct way to get the images on this page.
the year is returned in a URL variable:
to write the URL variable value to the page, use:
<?php echo(isset($_GET['horse_year_foaled'])?$_GET['horse_year_foaled']:""); ?>
in the WADAtbl_post recordset, you need to include the tbl_posts table in the select statement:
SELECT ads_horses.*,tbl_posts.* FROM ads_horses INNER JOIN tbl_posts ON ads_horses.adid = tbl_posts.postid ORDER BY adid DESC
jo271221
Join Statemetn to show image
The print work great! Thank you!
The Column 'adid' in order clause is ambiguous - I have zipped my attempts and here are the live pages:
ads_horses_results-ORDERBYadid.php
My most recent attempt show one horse repeating - ie only the 1st matching horse in the database I assume.
On this file I added a filter to just display ads with images
"SELECT ads_horses.*,tbl_posts.* FROM ads_horses INNER JOIN tbl_posts ON ads_horses.adid = tbl_posts.postid WHERE ad_category = '3' AND image IS NOT NULL AND image <> '' ORDER BY postid DESC"; so we could see just ads which have images and also ad_category is the id for the ads_horses
I also added this and the price and customer ID does not display, looks like nothing from the tbl_posts is displaying.
Customer ID: {WADAads_horses.customerid} ${WADAtbl_post.price}
I thought I had this working right away by simply changing the ORDER BY to postid, nearly sure I did. Therefore I tried again with
"SELECT ads_horses.*,tbl_posts.* FROM ads_horses INNER JOIN tbl_posts ON ads_horses.adid = tbl_posts.ad_category ORDER BY postid DESC"; Because the ad_category is the field that actual is common between the 2 tables, but here the image does not show up at all. Nor does the price or customer id
The FTP info is in message 8 on closed ticket #146365
Thank You!
change:
ORDER BY adid DESC";
ORDER BY ads_horses.adid DESC";
also, in the Data Assist search code block for each of the comparisons:
//comparison list additions
  $WADbSearch1->addComparisonFromEdit("adid","adid","AND","=",1);
  $WADbSearch1->addComparisonFromEdit("horse_name","horse_name","AND","Includes",0);
  $WADbSearch1->addComparisonFromEdit("horse_barn_name","horse_barn_name","AND","Includes",0);
  $WADbSearch1->addComparisonFromEdit("horse_breed_id","horse_breed_id","AND","Includes",0);
  $WADbSearch1->addComparisonFromEdit("horse_reg_yn","horse_reg_yn","AND","Includes",0);
  $WADbSearch1->addComparisonFromEdit("horse_reg_assn","horse_reg_assn","AND","Includes",0);
  $WADbSearch1->addComparisonFromEdit("horse_reg_number","horse_reg_number","AND","Includes",0);
  $WADbSearch1->addComparisonFromEdit("customerid","customerid","AND","=",1);
  $WADbSearch1->addComparisonFromEdit("fldstate","state","AND","=",0);
  $WADbSearch1->addComparisonFromEdit("horse_month_foaled","horse_month_foaled","AND","=",0);
  $WADbSearch1->addComparisonFromEdit("horse_year_foaled","horse_year_foaled","AND","=",0);
  $WADbSearch1->addComparisonFromEdit("horse_gender","horse_gender","AND","=",0);
  $WADbSearch1->addComparisonFromEdit("horse_in_foal_yn","horse_in_foal_yn","AND","Includes",0);
  $WADbSearch1->addComparisonFromEdit("horse_color","horse_color","AND","=",0);
  $WADbSearch1->addComparisonFromEdit("horse_hands_high","horse_hands_high","AND","Includes",0);
  $WADbSearch1->addComparisonFromEdit("horse_skill_id","horse_skill_id","AND","Includes",0);
  $WADbSearch1->addComparisonFromEdit("sire","sire","AND","=",0);
  $WADbSearch1->addComparisonFromEdit("siressire","siressire","AND","=",0);
  $WADbSearch1->addComparisonFromEdit("dam","dam","AND","=",0);
  $WADbSearch1->addComparisonFromEdit("damssire","damssire","AND","=",0);
if it rtefernaces a column that is in both tables, you will need to edit the code to specofy which table to look in, for example:
would need to be changed to:
$WADbSearch1->addComparisonFromEdit("ads_horses.adid","adid","AND","=",1);
jo271221
Still no image in joined table classified ads
I am sorry, my image is still not appearing - I have the image file name as
<img src="<?php echo $row_WADAads_horses['image']; ?>
No image appears
ads_horses_results1.php
<img src="<?php echo $row_WADAtbl_post["image"]; ?>
the same image recurs here
I tried adding this as well
$WADbSearch1->addComparisonFromEdit("ads_horses.adid","image","AND","=",1);
and that did not work
and
so I removed that. The only commen field is that ads_horses.adid and tbl_posts.postid
1. What is the correct image name?
2. Does the 2nd recordset ORDER BY tbl_posts.postid
3. Does the 1st ads_horses recordset order by ORDER BY ads_horses.adid DESC";
What am I doing wrong?
the select statement for the WADAads_horses recordset needs to refer to both tables.
instead of:
SELECT ads_horses.* FROM ads_horses INNER JOIN tbl_posts ON ads_horses.adid = tbl_posts.postid.....
it should be:
SELECT ads_horses.*,tbl_posts.* FROM ads_horses INNER JOIN tbl_posts ON ads_horses.adid = tbl_posts.postid.....
you don't need the WADAtbl_post recordset on the page, wherever you are trying to use the WADAtbl_post recordset, you should use the WADAads_horses recordset instead.
jo271221
Another print search results
I tried using the same scenario on this page - ads-events-news.php?SI=&Search=1 (bottom of the page) and I tried post and get and neither works for me.
<?php echo(isset($_POST['keywordfilter'])?$_POST['keywordfilter']:""); ?>&nbsp; <?php echo(isset($_GET['news_type'])?$_GET['news_type']:""); ?>&nbsp;<?php echo(isset($_GET['event_type'])?$_GET['event_type']:""); ?>&nbsp;<?php echo(isset($_GET['adssoldsign'])?$_GET['adssoldsign']:""); ?>
i dont follow, what is it you are trying to do on this page?
please be as detailed as possible. just saying it doesn't work does not give enough information for me to know what the desired result.
a description of what you are trying to accomplish and how the output on the page differs from what you are trying to accomplish will help me understand what the problem is.
jo271221
printing search results to display on page
I would like to "print" what is being searched on this page: ads-events-news.php ie if I searched for caption=country I would expect to print something similar that displays on the page so the user can see what they searched for and it displays on the page, When a new topic is searched the new topic displays.
On this page we have it printing directory-and-posts-horse-ads.php?id=6246&horse_year_foaled=2010&Search=Search
1 to 3 of 2010 Horses for Sale
your form uses the get method.
in this code:
you referencing a form element from the post method.
it should be:
<?php echo(isset($_GET['keywordfilter'])?$_GET['keywordfilter']:""); ?>
your form includes the following fields:
caption, keywordfilter, companyname, contactfirstname, contactlastname, city, fldstate, interestid
you will need an echo statement for each one.
