Data Assist Pages
Thread began 1/10/2013 11:32 am by john70964 | Last modified 1/11/2013 9:46 am by Jason Byrnes | 1697 views | 6 replies |
john70964
Data Assist Pages
Hello
I have been trying to Data Bridge to build a Search-Results-Details set.
The first set I built went right through the build but when I tried to use it a search brought in all records instead of the 6 or so I expected.
I deleted the pages and tried anothet few builds but no luck.
Now DW crashes out before I have built the Search page.
I have deleted the cs6 configuration file.
Any ideas what may be going wrong please?
I am using XP SP3
Many thanks
John
john70964
Thanks Jason,
I thought I had found the answer.
I closed and restarted the machine.
Was almost through the wizard but it closed as I was finishing the Details page.
I will try again tomorrow and contact you later.
Regards
John
john70964
I wondered if my problem here was the site installs
Local Site Folder C:\xampp\htdocs\boatsforsalenow\
I am using the same folders for remote and testing.
C:\xampp\htdocs\ is localhost
do you have a testing server connection set up in the site definition? make sure the testing server is connection to the same location.
john70964
Thanks Jason
All three server had the same address. C:\xampp\htdocs\boatsforsalenow\
I unticked the remote server and I was able to get right through the process.
At the finish the search page has lost its formatting and there were a few other problems so I will re build when I have some spare time.
ok, glad to hear you got it working.
