gallery throws of layout
Thread begun 1/10/2013 1:23 am by JamieEff | Last modified 5/01/2013 2:02 am by Jamie | 6210 views | 18 replies |
JamieEff
Hi Jason (and Happy New Year!)
Just wondering what I am missing that is causing this test page to throw off the layout?
test.php
Basically, am trying to use 'Slideshow - Wide' in the sponsors panel on the left hand column. It should look like this: index.php
Many thanks
Jamie
the left hand panel is not big enough for the gallery,
you wont be able to add the gallery to the left side navigation, the left side navigatin is too narrow.
your trying to fit a box that is at least 550px wide into a space designed to accommodate 250px...
you will need to add it to the main content div
JamieEff
thanks Jason...
what the minimum space required for the gallery side of things?
on that gallery the toolbar width uses 937px.
JamieEff
Sorry to be a bit thick but do you mean the way I have it set up or that is the default with that gallery style in particular?
that is the default for that gallery style.
JamieEff
sorry to dredge this one up again but just wondering if there is any way possible to create a slideshow gallery style that could be a different width ?
In power gallery 2, you can use the gallery design editor to change the gallery settings such as width.
JamieEff
I have done that lots of times with other installs but when I did that with the slideshow gallery it threw the whole sitemlaout off and led me to start this thread......
i would have to see the problem to troubleshoot.
