Another session problem!
Thread begun 1/09/2013 12:24 pm by mrs | Last modified 1/09/2013 1:33 pm by Jason Byrnes | 2058 views | 3 replies |
mrs
I have a session variable from the SecurityAssist created login pages called SecurityAssist_UserID, and this is being populated fine... I can use this session variable in many places.
I have come to use this on a totally different page to others where I have used it, and I am currently trying to use it in a recordset, but the recordset isn't working as I expected! This is the recordset:
$colname_rs_users = "-1";
if (isset($_SESSION['SecurityAssist_UserID'])) {
$colname_rs_users = $_SESSION['SecurityAssist_UserID'];
mysql_select_db($database_conn_mrs, $conn_mrs);
$query_rs_users = sprintf("SELECT * FROM tbl_users WHERE UserID = %s", GetSQLValueString($colname_rs_users, "int"));
$rs_users = mysql_query($query_rs_users, $conn_mrs) or die(mysql_error());
$row_rs_users = mysql_fetch_assoc($rs_users);
$totalRows_rs_users = mysql_num_rows($rs_users);
As you can see, I am trying to pull through the users info based on the session set when he logged in, but it's not working. I am trying to display the content of the users account on a page, by dropping the bindings onto the page from the recordset, but I am just getting blank regions. The binding of the session variable is displaying fine though!
Again... what am I doing wrong?
Thanks.
try adding the following code at line 1:
<?php @session_start(); ?>
if you add the following code in the body of the page, it should show the recordset query:
<?php echo($query_rs_users)l ?>
what is the query being returned?
mrs
Sigh... hours I've been at this problem. In fact, several days on and off!
What exactly is that doing then? Obviously it's starting a session, but I assumed one already existed from when the user logged in.
If I have more than one active session, do I need more than one @session_start?
Thanks Jason.
no, you only need one @sesson_start() line.
it needs to be on any page that uses the session. PHP often loses visibility to the session unless it is forced to look for it by using the session_start() command.
