show delete if not in both tables
Thread began 1/09/2013 11:22 am by randyw2394710 | Last modified 1/09/2013 1:54 pm by randyw2394710 | 2378 views | 7 replies |
randyw2394710
i have two joined tables gallery and gallery history i was able to show inserted and updated now if i delete from gallery and not history i want to show deleted
if ("".$row_gallery['created'] ."" == "".$row_gallery['historycreated'] ."") { // WebAssist Show If
Inserted
} // ("".$row_gallery['created'] ."" > "".$row_gallery['updated'] ."")
if ("".$row_gallery['created'] ."" > "".$row_gallery['historycreated'] ."") { // WebAssist Show If
Updated
} // ("".$row_gallery['created'] ."" > "".$row_gallery['created'] ."")
if ("".$row_gallery['pg1_gallery.id'] ."" != "".$row_gallery['pg1_galleryhistory.id'] ."") { // WebAssist Show If
Deleted
} // ("".$row_gallery['id'] ."" != "".$row_gallery['id'] ."")
and the record set
SELECT count(pg1_gallery_images.imgsrc) AS `number of images`
, pg1_gallery_images.*
, pg1_gallery_images.photoComment
, pg1_gallery.id
, pg1_gallery.created
, pg1_gallery.GalleryName
, pg1_gallery_images.gallery_id
, pg1_galleryhistory.*
, pg1_galleryhistory.id
, pg1_galleryhistory.historycreated
, pg1_galleryhistory.historyGalleryName
, pg1_gallery_images.watermark_text
FROM
pg1_gallery
LEFT OUTER JOIN pg1_gallery_images
ON pg1_gallery.id = pg1_gallery_images.gallery_id
RIGHT OUTER JOIN pg1_galleryhistory
ON pg1_gallery.id = pg1_galleryhistory.id
GROUP BY
, pg1_gallery.id
, pg1_gallery.id
ORDER BY
pg1_gallery.id DESC
you may have to change the join types being used in order to accomplish this.
when the gallery is deleted the $row_gallery['pg1_gallery.id'] will return NULL
so use:
if($row_gallery['pg1_gallery.id'] == NULL) {
randyw2394710
ok i did this
if ("".$row_gallery['GalleryName'] ."" == "") { // WebAssist Show If
Deleted
} // ("".$row_gallery['GalleryName'] ."" == "")
deleted shows up but inserted is still there
randyw2394710
i think i got it to work
randyw2394710
how do you show only if two rows are equal
should already do that
randyw2394710
yes i thinks its good have to make sure all criteria is the same or different i was close just needed the push thanks
you would need another condition around the inserted if statement:
if ("".$row_gallery['GalleryName'] ."" != "") { // WebAssist Show If
Inserted
} // ("".$row_gallery['GalleryName'] ."" != "")
